Packages |
Please use the map to help you select the appropiate solution.![]() |
20 Watt Meraki
If you live in the red geographies, we suggest you buy one of these packages.
40 Watt Meraki
If you live in the orange geographies, we suggest you buy one of these packages.
Provide-Your-Own
If you live in a yellow geography, you must buy a 3rd party solar panel (60 Watt capability or higher) to use the Meraki Solar. This package includes the Meraki Solar Connector cable to connect your panel to the Meraki Solar radio.
Features & Benefits |
Cover Hard to Reach AreasCloud Controller |
Cloud ControllerInstead of requiring you to install and maintain expensive network monitoring equipment and IT personnel, Meraki's data centers host all of the network services allowing you to build and operate a high-quality wireless network at a disruptively low total cost.
We’ve reexamined every aspect of large scale wireless design. Our management software is completely hosted, which means you don’t need to buy any software licenses and purchase, configure, and maintain management servers. In addition, we don’t rely on controllers, eliminating an expensive hardware component. Robust mesh networking dramatically reduces the amount of wiring and installation needed, reducing costs and speeding deployment. The Meraki system features revolutionary usability, and it works right out of the box - no additional purchases neccessary. Simple and fastMeraki makes it easy to setup large networks quickly. IT professionals save time since they don’t have to learn a complex architecture or attend lengthy training sessions. Plus, Meraki includes most commonly used networking components, so there’s no need to perform a complex systems integration effort to get your network up and running. It takes days, not months.RobustWith close to 10,000 networks deployed, Meraki software is used to run more mesh networks than any other vendor. Our robust hosted services tools enable you to configure, monitor, and maintain your network remotely.Cost EffectiveMeraki saves you money. By eliminating the need for costly controllers and management software licenses, we reduce your upfront investment. In addition, our mesh means you need to run fewer wires, reducing costs and network deployment time. Finally, our easy to use software means you need to invest less management time over the long haul. EditionsPro EditionEvery Meraki network comes with Pro Edition included for the lifetime of your Meraki device. Pro Edition provides the tools you will need to get started with Meraki, including our revolutionary Dashboard management tool.Carrier EditionMeraki Carrier Edition provides the tools carriers and large operators need to provision, monitor, and monetize large wireless networks covering tens of thousands of subscribers. Start Learning about our Cloud Controller Platform |
Want to learn more? |
